SSTKO81
- Joined
- Jun 1, 2009
- 354
Good morning everyone! HOpe your 4th of July was great. Mine was dry, as my boat sat on the trailer rather than the blue waters of my local lake. The problem? No ignition. I didn't have a very good spark, which led me to believe the coil was weak (the old one was leaking oil from inside the terminal) but I replaced it and that seemed to help. but still no ignition. I cleaned the plugs. -nothing. I checked the wires -nothing. I made sure the carb was working, choking, breathing, etc. -nothing. So now i've got spark, fuel and air.... Someone suggested points, but ive replaced them with the pertronix system. When I installed it I DID NOT use the "diode fix". But I tried it and still nothing. I guess my timing could be off, but it should still at least try to start... Is there a resistor line going to the coil that should be replaced? I'm losing my mind here... Anyone ever seen this before?
