- Joined
- Mar 8, 2009
- 44,427
Been using my engine hoist for remove and replace the outdrive. It works pretty well but does not keep it level. Only used my engine stand a couple times and after seeing some of your drive jacks that got me thinking. Make 3 tools in one. Here is my engine stand, Drive Jack remove/replace, and Drive stand. Only thing I still need to add are clamps to hold the drive when I turn it. Could also use something to change the angle to level up, currently use a wood wedge slide in between bolt across the back.
After doing this job, I should have used heavier angle welded to the jack. The Bravo 3 puts quite a bit of torque load on the steel I used. I added another 1 1/8 box tubing under it to stiffen it up. If I used some 1/4 thick angle I had it would not have been needed. Maybe later I'll cut it off and redo with the heaver metal.
