3 way switch question
FBPirate95
My outboard trim trim switch on my side control has broken. Instead of spending $40 bucks on a new switch can I use a mom on/off/mom on switch? This it the switch I have, but I'm not sure how to wire it. There are only three wires coming from the trim motor. One red, one blue, one green.
Any advice?
seabob4
Re: 3 way switch question
Yeah, you can use it if you want...
Red to terminal 2, Blue to terminal 1, Green to terminal 3. Toggle switches work where the opposite terminal is energized regarding the way the switch is pressed. Press the top part, the bottom terminal is energized, and visa versa...
FBPirate95
So nothing at all goes to 4,5,6?
Silvertip
Honorary Supreme Mariner
The switch you show is the same as having two separate ON=OFF=ON switches in one housing. If you don't need the second side, it does not need to be wired. Keep in mind also that using this switch is a bit risky. Trim switches are MOMENTARY action meaning they return to OFF when released. If this switch is not that way, you risk motor damage by not turning the switch off.
seabob4
Silvertip,
Even though it's a bit confusing, I think he got his point across...
Momentary on/off/on...
FBPirate95
Thanks guys. And yes it is a momentary on - off - momentary on switch.
Silvertip
Yup -- missed that little tidbit in his post. Sorry dudes.
