3 wire 12 gauge wire
Scuda11
Hi guys, quick question. Just rewired the boat as part of the rebuild and we installed nice, heavy gauge wire. In it is 1 black (neg), 1 white (pos) and 1 green (grnd). When I am hooking up my nav lights for example, what should I do with the green wire up forward? And at the terminal block do I ground it?<br /><br />Thanks in advance..
Ralph 123
Re: 3 wire 12 gauge wire
That wire is intended for AC not DC, hence the three wires. DC is 2-wire usually yellow (neg) and Red (pos) or Black (neg) and red (pos). If you are going to use that wire you have for DC, you just use 2 of the 3.
18rabbit
What Ralph said. I was trying to think of something creative you could use the 3rd wire for but nothing comes to mind. It won't hurt to connect it in parallel to your gnd since it's already there, i.e. use two wires for ground instead of one.
You could... nahhhhh, that would never work anyway... lol! Looks like you just got a spair wire for backup.
JustMrWill
Master Chief Petty Officer
Originally posted by BlackKnight755:<br /> You could... nahhhhh, that would never work anyway... lol! Looks like you just got a spair wire for backup.
What good will that wire do when they are backing up? :) <br /><br />-JustMrWill
SeaTrek
Yawl forgetting one thing.....<br />If that's NOT marine grade wire, you better cross your fingers.<br />Marine D.C. copper wire has more strands of copper than hill wiring and the compounds used in the insulation are different also.<br /><br /> :eek:
Perfidiajoe
That wire sounds like romex wire, if it is, it is solid core, Do not use any solid core wire for the boat! You can buy 2, or 3 wire marine cable, as this is what you need! Good Luck, Joe
