30 hp four stroke Tohatsu
Russ howerter
Engine will not start or hard to start changed fuel bulb. Checked Schrader valve fuel comes to top of valve
pvanv
What is the model? Older models had carbs. If EFI, what is the fuel rail pressure? Is there spark signal from the ECU?
airshot
If you not understanding these recomendations, you might need to find a repair center.
