bullcity101
Thread starter- Joined
- Mar 30, 2012
- 73
good morning!
I will start with, I am very furstrated that I can't figure this issue out. ugh! I will start with the issue and then tell what I have done already to try and solve the issue.
I have a 1985 envirude 30hp. The issue is, it will run for a few seconds after I pump the manual primer (not the primer bulb, the primer that is ran via tubing off the float bowl). and after that fuel is consumed it dies. After that I have to pump the primer bulb till firm and the pump the primer, and then have the same results.
Now here is what I have done. I have rebuilt the carburater, and cleaned the entire thing with carb cleaner and compressed air. I did a thorough job, taking out every plug and blowing out every oriface and every jet. After doing this and having the same results, my thought came automatically to the fuel pump. I took off the fuel line to the carb and turned the engine over and the fuel shot out two or three inches, so this tells me the fuel pump is working correct? Is two or three inches enough pressure? I took off the cover to the pump and check for blockages in the screen and it is very clean. I have also, put in a water sperater filter, this is after the fact so i don't think that is the issue. And i don't think bad fuel is the issue as it purs like a kitten for 10+ seconds with the primed fuel. Compression readings are great, ingnition is working properly. Any ideas?
Also another question is, is there a bearing for the low speed needle deep in there on this model carb? Also what is the stock setting, I took it to firm and took it 1 and a half turns out. Is that enough? Could that be the issue? I also thought that the float needle is getting stuck, nope I can hear the float move when i shake the carb, I also just had it open and put brand new stuff in.
If you would like me to post a video, just let me know.
Please give me all the suggestions you all have.
Thank you in advance, you all are so helpful!!!!
John
John
