Re: 30 hp nissan flywheel troubles
How did you manage to shear the woodruff key? The flywheel is intended to mount to the tapered shaft, DRY, and properly torqued. If the taper was oiled or greased, the flywheel will come loose. The new key is: 334001310M MAGNETO KEY $2.98. If you need to replace the coil plate assembly (with both coils), you will indeed need to know the correct model, not year. For the NS30A3, the correct part is 3A0060020M COIL PLATE ***'Y $399.43. For the NS30A4, you would need 3P0060020M COIL PLATE ASSY. 25C3 & 30A4 $405.45. Now then... if you only need one of the coils, that might be available, and likely at a lower cost. These bits are available from any dealer (including me). What is your ZIP code?
