302 I/O stalling
G462
I have a 73 Sea Ray I/O with 302 888. I just replaced the old engine with a used complete 302. Everything went well at home running it off the garden hose. The engine started and went into gear without problems. When I try to put it in gear in the water it stalls instantly and then it?s difficult to start. Any ideas motor or drive problem?
JustJason
Re: 302 I/O stalling
did this used motor go in with all new tune up parts?
if not.... then that's a good place to start.
if it did, then check start by checking your compression.
Ayuh,....
My WAGuess is,...
The lower shift cable has bit the Dust,+ needs replacement....
