305 heads
Clark in Michigan
I have a 1979 GM 305 Mercurser with a cracked head.
The question I have is.. Will the heads off a 88 GM 305 OMC have the same bolt pattern?
If not will automotive heads work?
Thank you
Re: 305 heads
the head has a casting number. replace it with another of the exact same casting number. you will most likely find the head on a truck in a salvage yard.
the 88 heads will have the same bolt pattern, however different combustion chamber and will be center mount valve covers. you should stick to the 78-85 castings or swap both.
Clark in Michigan
Re: 305 heads
Thank you for the reply Scott,
So I could swap both of the heads with the omc heads?
Failproof
Re: 305 heads
Yes, you could swap both heads. Depending on CC's of combustion chamber of the new heads vs the old heads, you may be lowering your combustion pressure. Eg: going from 9:1 to 8.5:1. Looking at casting #'sto should tell you. Plus runner lenght/size/shape may be different, changing torque/hp curve. But yes they will bolt on. While they are of look to see if your block needs drilled for the "extra" coolant passage. The head may have an extra passage that matches with the gasket, but have a blank on the block. It is often recommended to drill to prevent steam pocket.
RogersJetboat454
Re: 305 heads
It must be mentioned that the angles of the intake bolt holes for the center 4 bolts on the '88 heads are different then older heads, and would require the use of a matching intake manifold for a guaranteed fit.
If you don't have the intake with the heads, you will need to find one. If you want a direct fit for your heads, look at the casting numbers for your heads, and match them to something out there. Your heads are no different then auto heads (no marine specific heads), and the casting number would most likely match something that was offered on a pre '87 truck. You may be able to score a pair of reman heads for short money.
RogersJetboat454
Re: 305 heads
Extra cooling passages, steam pockets, and drilling things is only a concern for the 400, due to it's siamesed cylinders. The 305 has the same standard cooling ports and passages as most other small blocks.
Clark in Michigan
Re: 305 heads
Thank you all for your help.
I think I will start looking for some old truck heads.
Thanks again
RogersJetboat454
Re: 305 heads
Thanks again
Like it has been said, match up your casting numbers. You want to make sure you get something compatible. Heaven forbid someone has a pair of heads they thought were off a 305, but turned out to be 350 heads. Performance would take a nose dive due to the compression loss.
Good luck!
Re: 305 heads
not to mention the shrouded valves.
