305 mercruiser runs great and drives when cold when warm will run but chuggs out
Dukeab
I have a 79 century arabian with a 305 merc with a 898 outdrive. Well i have had a excellent tune up replaced all the fuel lines, pickup tube, check valve, both fuel filters, plugs, cap, rotor, dwel land points set correctly, carberator rebuilt professinaly, i run 93 octane non-oxynegated gas, and i have replaced log style manifilds and the flappers for the exhaust . Still having the same problems. Finally last time i took it out we cruised around for a while stopped and i couldnt get it to move. It would run just fine until i put it into gear. We timed it while out on the lake but could only get it to run good around 12* bdc shold be around 8* bdc. checked the timing chain to see if it is stretched. 5*-6* of play in the timing chain. I read thats within tolerance. Right? The thing is i can turn the shaft of the distributorwith my fingers not much but a few degrees for sure. is that normal? Is that a mechanical advance that replaces a vaccum advance? Secondly if the mechanical fuel pump is bad will it always leak into that glass bowl? please help. and fast. summer is going by fast!!
moffitt77
Re: 305 mercruiser runs great and drives when cold when warm will run but chuggs out
I had the same problem and mechanics couldn't figure it out. It would run great when cold, then die when hot, start and die when I'd put it into gear. I had a cracked coil and fixed it myself.
Dukeab
Oh yeah I have also replaced that. One of the first things i did. Both old and new coil ohm good hot or cold........
Dukeab
Oh and they both throw good spark.
quick2500
What's the total spark advance? Are you at low idle with the vacuum advanced disconnected when checking base timing?
Ayuh,.... There is NO vacuum advance on a Marine distributer....
quick2500
yeah bond-o, my bad.... got stuck in car mode for a second..... ooops A total advance check will let you know if the weights are sticking. Might be why your initial timing setting isn't looking right.
