henleyhale
Thread starter- Joined
- Oct 5, 2013
- 136
Unless you need more than 27 ft lbs to keep it tight it was tight, but i think your right silvertip, i did infact have a choke spring that was gummed up, after i cleaned it off thats when she started backfiring through the carb, which is when i started fiddling with the timing. So now what rpm do i set timing at. And what degree btdc? My seloc says 8 and didnt state an rpm. I figured it was at idle. Btw the turning in the hole is side to side movement. Like its loose in the hole back and forth side to side. That and some missing seals is why i got the new distributor
