bubbasblazer
- Joined
- May 10, 2010
- 30
I have a 30hp 2 stroke M30a3 that has been giving me trouble for quite some time now. It's my duck boat and occasionally use it for fishing. Last season the boat would run fine then die out similar to letting go of the handle on a push mower. I replaced all the lines , fittings, primer ball, cleaned but not rebuild the carb. The problem was still there. So I emptied my tank and found a piece of foil from a 2 stoke oil bottle in there. I assumed this was my problem. It runs fine in a tank or with muffs. Took it out this year after putting fresh fuel in it and a disassembly and cleaning of the carb, and the problem is Still There. I'm running out of ideas. Any help would be appreciated. Thanks.
