rs2k
Thread starter- Joined
- Aug 2, 2008
- 486
To begin with, even though the engine sounds and runs great at anything above idle, I do have some carburetor issues that should be resolved shortly.
I have a 2800 lbs trihull IMP Pawnee with a Chevy 305. WOT with a decent 14x16 cruise prop is 3500 RPM and max speed is 32 MPH verified by GPS (No wind or current).
I also tried an old chewed up 14x14 non cruise prop and got 4400 RPM at WOT and the same 32 MPH verified by GPS (No wind or current).
The engine does not sound that much louder at 4400 as it does at 3400 and it sounds much louder than when running at 3000 which give me 26 MPH on the 14X16 and 24 MPH on the 14X14.
The numbers above make me suspect a bad Tach, but I don't know what kind of speed this boat should be making. 32MPH for a big V8 in a little tri-hull seems slow to me.
This boat has plenty of torque and acceleration. I was able to get it and a second boat up on plain while towing it back to the shore. Pulling a person on a tube doesn't even phase it. It's the top end that's I believe is lacking.
Engine info:
1982ish Chevy 305 HO with 4MV Q-Jet and stock intake bolted up to an OMC Stringer 800 with a 14X14 / 14X16 prop
Engine info:
