Re: 32mm carbs in place of 28mm carbs
I am fairly new to two cycle engines also. The only reason I can talk about the 150,175 ,200 is that is what I have and I have been doing a lot of researching. I also met an old suzuki mechanic that has worked on suzuki's since 1978 but he still could not tell me about the swap. He said that suzuki tunes their motors so tight the smallest change could make it not run well at all so when we started looking at the carbs he thought I should wait until he could get a solid answer on what the real diff. was.
I also found out that they changed the water jacket design so 1986 head gaskets will not work on a 1987.
Maybee the water jackets were changed to help with cooling when they started to run the motor a little leaner.
Anyway I did buy a set of 1994 carbs and as soon as they get here we will know how it all works
I am one of those people who cant help themself seem like I am allways getting into a new project. I traded my 1967 chevy c10 with a built 283 I mean it was built ! for this 19' bass boat with the 150ss on it the motor seemed to be ok on the muffs but when I droped it in the water it was junk
And so now I get to learn about outboards but thats ok I am pretty good with mechanical work maybee next I will try a rotory engine that what my RX8 has in it and they are quite intresting.
Thanks for all your guys help I do get to learn a lot from these forums
