33 hp 1968
jbabcock
Not sure whats going on here replaced head and water jacket gasket the other day took motor out ran like a dream never had it run so good then took it out today runs great at half throttle then when going full out motor revs high almsot like prop is covered in weeds gets that low deep hollow sound to it and looses all thrust go back down to half throttle motor runs fine wondering if this is a bad base gasket or if there is something going not so good in my bottom end changed the oil and checked the shear pin today all looked fine.... any ideas ????
TrueNorthist
Re: 33 hp 1968
Sounds like it's cavitating. Did you raise the trim angle? (Bow up) My old Crestliner Mustang used to cavitate badly if I raised the bow too much.
Daviet
Re: 33 hp 1968
Engine revs up, boat slows down. You checked the drive pin, but did you check the hub in the prop to see if it was spun?
jbabcock
Re: 33 hp 1968
not sure if you can spin that prop the shear pin goes straight threw it however i did just take it off and noticed there is a channel for like a keyway in the drive spindle and prop and that steel key isnt there?
tx1961whaler
Re: 33 hp 1968
There is only the drive pin there, with the prop nut and cotter pin.
A spun prop is where the rubber hub in between the inner hub and outer prop no longer holds and the prop "spins" on the inner hub at high torque. If you mark a line with permanent marker across the back of the prop you can tell if it slips after running it.
jbabcock
Re: 33 hp 1968
Thank you that was very informative i had no idea there was a rubber seal in the middle i always though it was one solid brass pressed in fitting its a fairly new prop onle 3 years old but it has met a few stones and bottom a couple times so i will try one of my spares tommorrow thank you again for that info.
samo_ott
Re: 33 hp 1968
Meeting a few stones will make a 3 day old prop spin!
jbabcock
Re: 33 hp 1968
Yup thats what it was just a bad prop put the spare prop on and moter worked fine kinda a bumber that a prop thats 20 years old outlived a prop thats 3 years old but thems the breaks.
