35 evinrude missing
dew2
I friend has a 35 Evinrude 1980. The lowspeed trolling works great 3/4s full throttle runs fine, but open it all the way and there is a bad miss.The compression is 100lbs both cylinders,new plugs,New fuel line,Spark at starting jumps 7/16 inch bright blue zap.
I need suggestions the motor is 300 miles away,He tried everything I could help with. Thanks for replies!
boobie
Re: 35 evinrude missing
Just guessing, maybe a bad power pack with out checking out when the prob occurs with the proper equipment.
gus-gus
The title was a touch misleading. I am glad it wasn't "missing" but running rough. Good luck.
dew2
Are you sayind a multimeter with a DVA check? Will it show a bad pack at low speeds even though the problem occures at high speeds?
boobie
For high speed misses a timing lite or a cyl drop test work the best. That way you can narrow it down to which cyl/cyls is giving you the prob. The DVA is mainly used for cranking output tests.
Home Cookin'
simple as this is, pliers-tighten the battery ground. Worth a try.
steelespike
Is that skip bad enough it feels like you hit something?
boobie
Battery ground has nothing to do with the ignition system on this mtr.
dew2
No, Well actually the motor isnt here I am communcating with a friend 300 miles away,The lower gears and dog are new.
AlTn
voting with boobie...an inductive timing light on each sparkplug wire in turn will best diagnose what sounds like an ignition problem..or eliminate the ignition as the source
dew2
Thanks guys! Hopefully this will find the problem with out throughing parts at it.
