puddleboater
Thread starter- Joined
- Oct 5, 2009
- 38
Greetings,
This is my first post and am hoping for some help.
I bought a mid to late 1960s (?) Chrysler OB. I don't know what year it is and haven't been able to find any plates or inscriptions anywhere on the outboard about it's year or serial#. Anyway, it has two control levers; one for F-N-R and the other is for accelaration. The last time I had an outboard with this type of control was on a 1959 Johnson 35HP OB.
The motor fires right up and has good water discharge.
I took the boat out for a trial run and it would only run at slow speeds (5-6 mph). When I try to accelarate, the motor begins to stall until I back off. Going to mid-range doesn't happen, as the motor dies. Once the motor dies, it takes several attempts to re-start. My buddy believes that the motor is being starved of gas.
The previous owner had been fiddling with the control linkages and as a consequence, the motor would only go in reverse and neutral, but not forward gear. A friend of mine was able to adjust the timing and gear shift, to where the motor idles nicely and now engages in both gears properly. My friend also repeatedly got the motor to rev up wide-open while in neutral. It's only when it is under load that it dies beyond 5-6mph.
Any ideas as to what our problem could be?
Another thing is the previous owner placed the fuel tank (portable six-gallon) at the bow of the boat (13 1/2 foot runabout), which I thought was unusual given that almost every boat I've owned had the tank near the stern. In addition, the fuel line primer bulb takes longer than normal to fill up. There is also no ingnition switch. Starting the motor requires crossing two wires, which doesn't really bother me. The remaing cables are a morass. The electric choke solenoid is also dead.
I'm not really concerned about these other issues, as I can remedy them. Perhaps it might help explain the cause of the accelaration problem.
Sorry for the long winded post, but I thought the more details the better.
Any and all constructive replies would be appreciated!
