FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Some food for thought.
I added a starter to my 02 Johnson 40. My starter bolted right into the the block but some motors will need a bracket.
I didn’t have a charging system or deep pockets so I just found a spot for the solenoid and called it a day. I use a solar panel to keep the battery topped off and once a season I will charge on the charger and that’s all I have ever needed. You could likely add a charging system but it get expensive. You can go to any parts site even here on IBoats enter your model number and look at the diagram for your motor and see what’s available.
Hope that helps.
Quick and dirty way, you need a starter with a solenoid, a bracket and a push button starter switch. The flywheel needs the teeth, but I don't think they came without on the 20-35's.
What year is your motor?
I have a starter and bracket from an 1985 30hp. Not sure if the starter works.
it just a parts motor that I have had laying around. If your interested I could send it your way and you can just send me the postage.
It's a 85 I in would really appreciate it. I have the starter just need a bracket
my address is
Doug garvin
1031 n euclid
Ontario, CA 91762
Just tell me how much you you want and I send a money order right away
Ok
I will take the starter off to save on weight as it will be coming from Massachusetts.
I will just put my address in the box and the postage will be on the box so when you get it just send me the money order.
A hurricane is headed my way tonight and tomorrow so weather permitting I will send it out on Monday.
Best
Tim
