ronboonville
Thread starter- Joined
- Jun 6, 2012
- 287
I am so close to being finished on my gale, only one screw left over. I bought a recoil off a 28hp johnson, it fits but is not drilled for the lever for the comp release. I could swap the upper housing from the old, but I'm afraid of having trouble with the spring. I pulled it a little and it fired. I only plan to use it for an emergency, like battery totally dead or starter quits. I have had 3 shoulder surgeries and I fall down as little as possible. As I get older, I try to get wiser. don't think it's happening. I think it is a good idea to have it on there because it keeps those ring gear teeth from cutting me so bad. another part I bought off the 28 was the carb. It fit and worked ok and only had a few differences, like only having 2 small holes in the top of what I would call the throttle bore. I switched back to the original 35 carb with a kit and new float in it because it kept dying, then I found the pulse hose was bad. My theory is more power with the 35 carb and better economy with the 28. So what would you do? leave the lever off or fool around with the recoil spring that seems in good shape. Also rope looks brand new.
