35 johnson 3cyl compression
buddyp
Checking compression on my 1999 johnson 3cyl 35.
1=110
2=110
3=120
Does this look within normal compression numbers?
My 1985 30 2 cly johnson has 130 on both cyls?
Thanks
hidef
Re: 35 johnson 3cyl compression
You want it to be within 10% which yours is the actual number is less critical. I would say yours is good. If you haven't removed the oil injection on that outboard do it. It needs to go as it is unreliable use 50:1 premix.
Borgey401
Your compression is good.
boobie
hidef is correct. Get ride of that oiling system on the mtr asap or your compression #'s won't be that good.
