flashback
- Joined
- Jun 28, 2002
- 4,031
Well once again I humbly call on you folks for some advice...I have spent about an hour with the search and can't seem to find an answer...
This is a 1979CC pre alpha drive with a rebuilt engine 5 years ago..On this past Sunday it was running fine, I started it up on Thursday and got about a half mile and it overheated. I put it in neutral and revved the engine and it immediately cooled back to normal. I let it idle for a while and all was good so I went into gear and got up to plane (about 2200rpm for me) and it started to heat back up. so slowed down to about 1500 and the engine started to cool, went back up on plane and the temp started to climb....So I say to myself maybe the thermostat is bad so I replaced that today but no improvement. I disconnected the raw water hose where it goes into the thermostat housing, cranked the engine and I got a good flow, probably around a gal a minute just idling. Thus my confusion, the raw water pump was replaced 5 years ago and the boat has never been in salt..I guess what stumps me it that this came on so suddenly and it seems I have plenty of flow from the pump, I thought I would check in with you folks before I tear into the pump.........Thanks FB
