MikDee
Banned
- Joined
- Jun 6, 2007
- 4,745
Re: 350 Engine advice--GOOD UPDATE!
I told you that boat should do 55 easy with the 355!
And that's GPS! Plus you're running out of prop now. There's more to be had there, I bet with a light load, and some synthetic oil you'd get to 60!
Do ya really think you need a cam, & better heads?!
Whatever, Good Luck, Mike
Ok, you don't say what size prop you have, if it was an orig. 230hp/305 it's probably a 19" pitch, and the rec. rpm range for that engine is 4400-4600rpm, and a 50mph boat as it was, considering I had an older 228hp/305 in (probably) a heavier 20' SeaRay bowrider that would do 50 with a 19" pitch prop, I'd say it's not the heads holding you back! There's something else going on!, that boat should do 55 easy with a 355. I suggest you go over that engine real good, it's got the guts to do more then that, even with a "plain vanilla" stock cam.
