350 mag 5.7l skipping
Riverview3
Totally lost, please help. 2007 Chaparral 236si with 350 mag 5.7l and bravo III. Boat cranks and idles great. When given gas to accelerate motor starts skipping and keeps skipping as long as you accelerate. When slow down back to idle it runs great. We have replaced rotor and distributor and the small Infiniti on piece up under it. New spark plugs. New spark plug wires. New rectifier. Any ideas???? Still skips when you accelerate. Seems like we are missing something because it runs so great until you accelerate.
Start with your fuel pressure, at idle, and under load
Did you inspect the contents of the fuel filters?
Riverview3
Yes the round filter was basically ok. And the little filter had very little sludge but not bad. And to our knowledge has never been changed. We tried to check pressure on fuel filter but it doesn’t have a screw in connector to attach a pressure reader. It is an oring and push in and snap connector.
dubs283
It is mpi. And it is an oring and push
the only fuel pressure tester port i've seen on a merc mpi is a shrader valve style on the fuel rail
can't say ive ever seen a fuel pressure tester port on or near a fuel filter, the closest would be an in-line adapter used on a carburetor that threads into the filter housing at the carb inlet
dubs283
mercury has a few different specs for fuel pressure but generally they are around 40 psi for mpi engines
be sure to take pressure readings throughout the rpm range and under a load, pressure should remain constant and not exhibit any major swings in readings
QBhoy
Sounds like water in the fuel. What plugs did you put in it ? Got to be iridium in these.
