clockwatcher
Thread starter- Joined
- Nov 8, 2009
- 289
1990 350 Mag/Alpha I. The engine will start and run for a while, then dies. Gauges stay on. It will start again immediately. Per Don S. in another post, I ran a wire from the + battery to the + coil and it runs perfect all day long. I installed a new coil and ignition sensor, plugs & wires, distributor cap and rotor. I replaced the engine to helm harness with a new one, no difference. I disconnected and jumped across the lanyard switch, no change. On the ignition switch, I jumpered from the Orange to the purple, no difference. Is that the correct way to test the switch?
Per the wiring diagram, it appears connection could be broken at the tach. Is that correct?
What should I try next?
