350 Mag Injectors not firing
lilhuff
Per a previous thread input I know have spark. I am working on a 2002 Ski Centurion that sank in shallow water. It has 350 Mag MPI with ECM555. I ran down the chart and replaced the coil and now have spark, and fuel pressure at the rail and it will fire with a shot of starter fluid but I believe it is not getting any fuel thru the injectors. Is there a sensor possibly a crank sensor that tells the ecm when to fire the injectors? How do you trouble shoot the injectors? I looked for a similar chart for the fuel system but it did not go to the injectors.
Any help will be greatly appreciated.
