- Joined
- Mar 8, 2009
- 44,649
No
To obtain zero lash hold the push rod with your fingers and feel for up/down slop. Loosen the nut until you feel some up/down movement, turning movement is not used. Once all up/down is gone, this is zero lash. Now turn the nut down one full turn, your done with that lifter
I use a grease pencil and mark nut once done. I also adjust any others that are next to another valve being opened. If valve is being opened then the other of same cylinder is closed
