silver_power
- Joined
- Jul 8, 2009
- 327
Thank you very much. ...by the end of this week I will have further details concerning fuel pressure. Thank you very much.
Without trying to highjack silver_power's topic and we all await his latest testing's......I'll just mention in passing only that being you have an 2003 engine, your issues became known to Mercruiser and the repair for them was to replace the ECM....That mentioned, when I went looking for similar type issues you're having and while talking with Merc after the warranty timeframe expired, one of the service tech supports mentioned (described) what was happening was the ECM sensitivity was programmed to sensitively for reading (or sensing) the shift interrupt switch "vibration" while it was mounted on/to the engine mounted shift cable plate assembly.I have a 350 mag mpi, 2003 and have been watching your problem . I had the same problem and was hoping that you solved yours . I bit the bullet and bought the Rinda Diacom program for my lap top. it showed no codes under load but over 2200rpms it would stumble and then shut off. it would restart with no problem, no codes.
I had changed the shift interrupt switch and the gear position switch, no change. I plugged in the old shift interrupt switch and let it just hang there. the test run went perfectly with no stumbling and not shutting off. I plugged in the installed shift interrupt switch and it stumbled and shut off, I re tested several times and got the same results .
I had changed the shift cables (both) and throttle cable some months back. what I have found is that the shift cables must be out of adjustment and ty wraped too tightly, just enough to give me a good shift but was causing the shift interrupt switch to activate just enough to cause the stumbling and then the computer would shut it down. Still no codes.
I haven't had time to readjust the cables but I'm confident that I found the problem.
Try jumping the shift interrupt switch with a jumper or a Bravo shift switch jumper.
Good luck, hope this helps
George
