silver_power
Thread starter- Joined
- Jul 8, 2009
- 334
Update: The problem did not solved. The fuel pressure is 43psi (perfect), but the surge still exists. I left the boat to the mechanic to solve it. I am totally tired. Things are changed are: new plugs, new rotor and cap, new plug wires, new fuel water separator, new mapt sensor, new tps sensor, checked and cleaned fuel injectors, new fuel pressure regulator, checked compression leak down test (all cylinders 165-170 psi). I do not know what else to check.......
My boat does not have anrisyphon valve as the fuel pump is below tank fuel pick up. The test today was made with a remote fuel tank......
