350 MAG timing
captn jack
I have just installed a mallory ignition system and am ready to start up and set the timing. My harmonic balancer is to rusted to find the TDC and theBTDC &ATDC marks. Any suggestions how to procede ?? Captn Jack
zbnutcase
Re: 350 MAG timing
The balancer (if stock) has only a line cut into it as a marker. The actual timing marks are on a tab spotwelded to the timing cover;they rust to unreadable often. Is that what you mean? And if you didn't find any marks, how did you install the distrubtor? And that is a marine mallory you installed, right? 'nutcase
Bt Doctur
Re: 350 MAG timing
you could just drop it in and then use a compression gauge hose in #1. crank the motor feeling for the air while looking at the rotor.
remove all the spark plugs, slowly rotate motor ,using a wood dowel in #1 hole feel for TDC. will either be compression or exaust stroke.
Don S
Re: 350 MAG timing
Why would you get rid of a Thunderbolt ignition system to go to a Mallory????????
Only Fords had all the marks on the balancer, Chevy only uses a single line.
What year 350Mag are we talking about here?
zbnutcase
Re: 350 MAG timing
Exactly....but I wasn't gonna pry...'nutcase
Re: 350 MAG timing
Ayuh,.... Xs 3,..... The T-Bolt is the Best there is, your taking a step Backwards....
mla2ofus
Re: 350 MAG timing
To answer your question, find the mark on the balancer and sand it w/ fine sandpaper, same for the timing mark tab. Use some soapstone like weldors use and fill the marks w/ soapstone. Carefully wipe off excess w/ your finger and they should shine like a diamond under the timing lite strobe. A white lead art pencil will also work well.
HTH,
Mike
Don S
Re: 350 MAG timing
But that didn't answer his question, he asked how to Find all the numbers on the harmonic balancer, not how to clean up the tab and the mark.
mla2ofus
Re: 350 MAG timing
If you sand the balancer mark AND the tab, I'm sure he'll find all the numbers and marks there.
Sorry Don, I guess I don't split enough hairs!!!!
Mike
