350 Merc no spark?
Don S
Re: 350 Merc no spark?
What year? What ignition system? They aren't all the same.
Ayuh,... Welcome Aboard Hemiman,....
You've Really gotta read This, if you expect meaningful Answers.....
hemiman74
86 Mercruiser 350 alpha 1 lower unit It has thunderbolt IV Ignition
The module is located on the right side exhuast manifold. BUTT...... I put it all back together today and it started. So WTF? I think the ground on the bottom of the Distributer that goes from the ground on the module to a phillips head screw as you can see with the cap off. On screw is longer than the other as I was taken the pick-up coil out the nut that holds it on fell with no help from me unless it turned as I unscrewed it but most of the time you need a wrench on one end so...........Im putting it in the water friday gonna let it get hot again and go from there.
Don S
If/when it goes bad again, do these checks.
hemiman74
I pulled the ground off the Distributer just out of curiosity and started the boat and it fired right up. I think something got hot but even the next day it would not start, but thanks for the trouble test i will probably use it. It started two days in a row and this is my second week to own it. WTF!!!!:mad:
