350 mercruiser mpi over heats when trolling
walleye seeker
I have a 350 mpi that i installed in a 24' crestliner sabre yanked out the old merc 120 and upper unit and replaced with the 350 mpi and new drive i replaced the impellor with genuine merc parts. only runs hot when trolling as soon as i speed up to even 10 knots it cools right off in minutes
walleye seeker
Re: 350 mercruiser mpi over heats when trolling
:redface:
Thanks Don i just read start to finish i will check my thermostat as soon as i can dig the boat out of the snowbank still winter here.
My motor was a bravo that i converted to alpha 1 gen 1 since that is the drive i had i removed the bravo wter pump.yes that meant a new ecm ouch
Fun Times
Also while doing your testing you might want to keep this older service bulletin in mind just in case everything eles turns out good.
The bulletin is cut in two parts, Here is the first half.
http://www.marinemechanic.com/site/PAGE260.htm
And here is the second half.
http://www.marinemechanic.com/site/PAGE261.htm
And here is the link that everybody should save to make things like this easier to help out with for the next time.
http://www.marinemechanic.com/site/page19.html. :)
PS, You have a (PM)
