vroom ZOOM
- Joined
- Aug 15, 2017
- 474
2001 350 MAG MPI (MEFI 3). This one has me really stumped. Last year, it wouldn't run at all. I replaced all the spark plugs and the distributor cap and rotor, and it fired right up. Come springtime, the engine started right up, but upon acceleration would sputter and blow black smoke. I figured it was too rich so I put a fuel pressure gauge on the rail, and when I turn the key, the fuel pressure would jump to 70 psi and settle at 20 psi. When tried to start it the fuel pressure was all over the place and sometimes would peg my gauge, so I figured the regulator was shot. I put in a new OEM regulator, and the fuel pressure jumps to about 60 and then stays at 30 when the pump turns off. I tried to start it but it just fires once and then absolutely nothing. I tried a new sensor in the distributor but that did not help. When trying to start it the fuel pressure is jumping around 60 psi.
Thinking that maybe something was reading wrong, I hooked up my diacom laptop and looked through all the parameters. All the sensors were reading the correct values. No fault codes. I took the spark plugs out and they were all sooty. I cleaned them with a brush and the engine eventually started but it runs like a pile of poo. I decided to do a cylinder drop test so I started pulling the plugs off the injectors and broke one off.
two questions:
two questions:
- Any ideas on how to fix this engine?
- I badly need a new injector QUICK. how many pounds per hour are these injectors at 30 psi?
