Re: 350 Mpi Losing Oil
I am not 100% sure that oil coolers will solve oil consumption issues. I am not 100% sure that your oil is getting too hot either. I don't think oil coolers would be bad, but I don't think we have enough good solid data to indicate any solutions yet. I don't think we have enough good solid data to indicate any
problems yet. Ideas for making things improve? Maybe. But solutions will need to be based on good, solid data and frankly I have no idea what "acceptable" oil consumption would be on these engines. Based on my own experience, when running them hard I wouldn't be totally freaked out at a Qt. every 10 -15 hours. I woudln't like it, but I wouldn't lose a whole lot of sleep over it.
I do think you were a LOT heavier than that test data. Is that data from
your boat? Sister ship? Do you know how fast they will spin at WOT in your boat now? Let's say they would only run 4200 at WOT under the load you were carrying on your trek. If so, then cruising at 4000 RPM may in fact be the entire problem. My earlier comments were intended to say that we cannot categorically say that 4000 RPM cruise RPM is bad. We cannot say that 4000 RPM is too highly loaded either. We can say that IF your boat will only run 4200 RPM at WOT as it was loaded (I don't know, you'll have to tell us) that in that case 4000 RPM cruise would be less than good, and may cause higher than normal oil consumption.
I hope you understand that the only way to base any of these discussions is on reliable, repeatable data. For me that would start with WOT RPM at a normal load. And I would like to compare that with WOT RPM under the conditions you experienced what
appears to be high oil consumption.
My signature used to be:
In God We Trust, all others show us your data . . .
