haulnazz15
Thread starter- Joined
- Mar 9, 2009
- 3,720
So after rebuilding the transom, all new bellows/seals/gaskets for everything, getting the linkages hooked up and the starter rebuilt: we have locked up engine! We had found water in the left rear cylinder right before we put the engine back in, but we syphoned the water out put in some PB blaster/WD40 but it apparently did no good. Normally, I might just part out a boat with this issue, but with a new composite transom, all new seals, new bimini top, outdrive in good shape, new floor/carpet, reupholstered interior less than 2 years ago why not just rebuild the engine and have a new boat?!!
So, in rebuilding a 351W with about 750 hours (engine is a 75-76 model), what suggestions do you guys have for the rebuild?
Things I have in mind:
* Original Compression ratio per Seloc is 8.0, was wanting to go up to 9.0 if possible as we only run 91 octane and it is available dockside most places on the lake.
* Going to a 4bbl carb from the factory 2bbl Rochester and likely an Edlebrock performer intake.
* Should we stay at stock bore (just have cylinders honed) or go .30 over?
* Any particulars on regrinding the cam or crank? Possibly an upgraded cam, I know reversion is an issue, but how aggressive can we get without running into that problem?
* Any particulars on having the heads rebuilt? We will be getting all new valves, rods, lifters, etc as we might as well just make it a new engine to go with the "new" rest of the boat.
* We will likely be getting new exhaust manifolds/risers with all new hoses.
Anything else to keep in mind, suggestions, tips, tricks? I know there isn't a whole lot of knowledge on the 351 marine engines, but I need some guidance!
edit: We aren't looking to create a monster, just a solid engine to give another 30 years of trouble-free use! The outdrive is a 233 (pre-alpha) and original rated at 233HP, so I don't want to go above 300HP which isn't likely anyway, but just for your reference!
