351w ford engine
Status
Not open for further replies.
cwd60tx
I have a 1977 19ft.cobalt with a 351w and I just bought another 351 with fuel injected,my ? is since my oringinal engine has a holley 4 barrel is it possible to install the new 351 (jasper built) with fuel injection or do I have to change back to the carburated manifold? any help would be apreciated! Thanks Chuck
redjmp
Re: 351w ford engine
Fuel injection would require a high pressure fuel pump and possibly a fuel return line as well. Unless it is an old school mechanical style injection system you would need a computer to run it.
Kainon
money solves lots of problems, depending on the FI you got. check with the guys at http://www.azspeed-marine.com/ they may have a kit.
Also Edelbrock and Holley have parts you may be able to use.
the FI will gain better fuel management and performance.
I would've checked before purchasing.
haulnazz15
Unless you have the marine ECU that goes with the FI 351w, I would just pull off the FI intake manifold and put the 4bbl manifold on. It's quite costly to buy the ECU stuff, the carb'd version is just as powerful. The main advantage to the FI is just in quicker starting and slightly better fuel efficiency.
cwd60tx
Thanks Haulnazz ! I was thinking that myself,but I think I will get a after market intake manifold like Elederbrock or something like that,hope I spelled it right.LOL I am only going to use it in fresh water,we have several lakes around here including Lake Michigan.But other than changing the manifold I will leave it stock,it only has 26,000 miles on it and I am trading one of my black powder rifles for it A Ruger inline 50.cal stainless with a scope.going Saturday to pick it up. Again thanks for everyones help I just love Iboats!!!!!!!!!! Chuck:D
Lyle29464
be sure to change the core plugs and use all the marine bolt on parts.
cwd60tx
one more ? if I decided to go with the fuel injection can I just take the ECU out of the truck that I am pulling the engine out and if so what kind of job would it be to install it in my boat? just a thought
Aloysius
No. The truck probably has an O2 sensor. Keep it simple. Carburetor.
Do you have a cast iron timing chain cover with a fuel pump drive? May have to add an eccentric to the cam drive, or use an electric fuel pump.
cwd60tx
yes your right! I will keep it simply and use the manifold with the holly 4 barrel on it,I wont know about the fuel pump until I pick it up Saturday,but I will get a electric pump if need be.Thanks for your help,I was leaning towards the carbuarter anyway,just needed a little more in put and I got it:D
haulnazz15
I have the Edelbrock Performer aluminum intake on mine. I like it, and don't have any qualms about running aluminum intakes in fresh water.
cwd60tx
Hi Haulnazz, Edelbrock performer sounds great! can you tell me where to get one? Thanks Chuck
Fishermark
I'm not a Ford guy, but you can pick up the Edelbrock Performer manifold at a lot of places.... I personally like shopping at Summit - you can see your intake here.
haulnazz15
I got mine from Summit. I bought pretty much everything outside of the longblock from summit.
cwd60tx
Thanks to all of ya!!!!!!!!!!!!!!!!!!!I am sure I will be asking ya"ll ?"s as I go !!!!!!!!!Saturday I go pickup the engine,Today I put my Cobalt in Storage it has snowed here and its supposed to snow tomorrow burrrrrrrr its cold here in Wisconsin,but I will work on the motor in my unheated garage LOL.I am just so excited about this Cobalt!compared to my Larson this is a Ferrari.:D
cwd60tx
P.S. I will start posting pics shortly
cwd60tx
351w ford fuel injected
ok I just got my 1990 351W fuel-injected engine today and thought I would post a picture of it and the 351w 4-barrel carburated engine thats in my 1977 Cobalt,I have decided to put the carb and manifold on my new engine and take off all the fuel injected stuff and keep it old-school that is easier and I can deal with,sorry the pics are not very good but its snowing like hell here in Wisconsin! LOL The new engine is a Jasper remanufactued engine with 26,000 miles and runs great.Hope everything will tranfer over from my old engine to it(Manifold&carb) oh and yes I know I have to get a electric fuel pump..........any other suggestions or thoughts Thanks........if any one needs the Fuel-injected manifold and parts let me know
cwd60tx
Re: 351w ford fuel injected
Will try that bond-0 sorry really I am kinda new to computers and dont understand alot of this but trust me I will try! Didnt mean to do this but really BOND-O it really isnt a big deal unless it hurts your fellings!
Ayuh,.... I could really care,... I don't do Fords...
The Tip is for your own experince here at iboats...
If you keep the info of a topic in 1 thread, nobody's gotta go huntin' to figure out what's goin' on...
This is about the same motor swap as the thread I linked to this 1 for ya....
Don also tries to run a pretty tight ship in this forum,...
I just saved 'im a few keystrokes,... My guess is, He'll combine 'em when he finds this 1...
Just sayin'.....
Edit;,... See.....:D
cwd60tx
kewl thanks for the info and again I apoligize
Status
