35hp Mercury Power Tilt Trim motor upgrade
RBuch1974
Hello,
Hope I'v got this in the right forum but, looking to upgrade from a 35hp Merc w/ power tilt trim to a Merc 50-90hp.
Question: How large of a motor can I put on my exsisting power tilt trim?
Thank you for your help!
oldman570
Re: 35hp Mercury Power Tilt Trim motor upgrade
Your best bet for info as to how large of motor that wtll work on the unit you have would best be answered by going to the manufactures web site and getting the needed info from them. What is the manufacture of thr unit that you have? Factory or addon ?
Oldman570
RRitt
mercury generally used four systems from 35-90HP.
From 1996-2010 they used a light duty system designed for 30-50HP
From 1987-2010 they used a medium duty system designed for 0-120HP and outfitted with 60-120HP pressure springs
From 1987-1995 they used a medium duty system designed for 0-120HP and outfitted with 30-60HP pressure springs
From 1987-200x they used a pressurized assist cylinder with hydraulic lock on 30-90HP (aka manual assist)
The only way your existing mercury power trim will work over 50HP is if you have the 1987-1995 system and rebuild it with new springs.
RBuch1974
Your best bet for info as to how large of motor that wtll work on the unit you have would best be answered by going to the manufactures web site and getting the needed info from them. What is the manufacture of thr unit that you have? Factory or addon ? "
Oldman570
Thank you
RBuch1974
Thanks. The serial # is 0b225039. Ive searched with no success to find any specifications. Would you have a recommendation of where or who might I contact for a "rebuild" kit to upgrade if needed?
