3607 Aft Cabin Hyd. steering tank location
Gorwolf
I have a 3607 with a Hynautic H-50 steering system. The upper station is leaking fluid and I have removed it but hesitate to disconnect the hyd. lines till I depressurise the system. I think I can handle the rebuild but can not find the tank. Any and all suggestions gratefully received.
there is no tank. the system is a closed loop between the helm and actuator.
Gorwolf
Thanks, but the Hynautic H-50 diagram for the boat shows a 2 qt. tank and a 20 PSI air pressure charge. I am afraid of a major spill if I disconnect any of the lines without releasing the pressure first.
Gorwolf
FOUND IT!
For those of you who are still reading this thread.
It is NOT a closed system.
The accumulator tank is located under the rear stateroom mattress, starboard side. It has a pressure gauge (charged to 20 PSI) and a filler cap with a shedder valve in the cap, for pumping it up.
To open the lines without depressurizing would have been very messy.
