silver_power
Thread starter- Joined
- Jul 8, 2009
- 333
Hello,
I have twin engine boat with 2 x 377Mag Mpi Dts Axius. (S/N: 1A605669 & 1A605670)
The problem i have with the starboard engine is that it fires up ONLY the first time of the day. What ever attempt i try during ex. 10time period, it will not fire up and it will flood. It will not start, even with WOT. The only way to start, is to disconnect the power supply of fuel pump and start the engine. It will start at the second attempt without throttle at all.
The engine after it starts, runs perfectly. Something happens, only during cranking, and the engine floods
Checked till now:
1. Change spark plugs (the old were in very good condition and the combustion is very good, no oil, carbon etc)
2. Fuel pressure normally, 38-39psi@idle, 43psi with vacumm hose disconnected and 38-39spi during cranking
3. Voltage during cranking drops to 10.6V, 12.7V @StanD by
4. Change the fuel rail with the injectors from the port engine which starts perfectly without throttle
5. Change the ignition module and the common spark plug wire from the port engine
6. Pull out the temperature sensor and put a 390Ohm resistor so the engine see steady 72oC
7. Flame arrestor clean
8. Swapped the DTS throttle plate from the port engine
9. Fuel Filter new and the screen below them as well,
10. checked the water hose of the cool fuel module for blockage
11. Checked the FPR for destroyed diafragm and change it with new as it ruined during unistallation.
12. Check for faults with Diacom, all perfect (MAPT, etc) and no fault codes...
The next two things is to swap the distributor cap and all the spark plug cables with port's engine, but i am sure that this will be useless as if the cap-rotor -cables would be the problem, the engine would not started after unplugged the fuel pump, give a crank to clean and then connect it again.
Honestly i do not know what to check next........
Do you have any idea??
Checked till now:
