21cuddy
- Joined
- Aug 31, 2009
- 22
Old man winter cracked my 87 merc 350 block so I'm building a 383 stroker out of a newly acquired 96 vortec 350 block with a new 400 crank. I'm keeping the 5.7" rods but I am new to marine application engines. I have built a few hot rods. What pistons and rings are good for marine use that can handle 4500 continous rpms with around 10:1 compression? I hear that the ring gaps are different for marine use to allow a little blow bye, is this true, if so what should they be? I plan on using forged rods and balancing the entire rotating assembly and using new cast iron vortec heads to increase the horse power. I just want a nostalgic lumpy idle hot rod that will handle continous high rpms. Any ideas?
