Making Waves II
- Joined
- Jul 3, 2018
- 6
Looking for help. When I started my recently rebuilt 396 Big block engine, I poured a little bit of gas down the carb and the engine started right away. After a couple of minutes the engine quit running. I tried to start it again and the engine runs fine for a couple of minutes then it quits. I noticed that the primary jets don't have any fuel coming out of them but the secondary Jets do. I changed the fuel pump thinking the old one might be weak.I took apart the primary fuel bowl and checked the float and needle setup. I lubricated everything and couldn't find anything wrong. I'm wondering what else I can check before I take the carb to a professional for rebuilding ( I'm not convinced that is the problem). Can the anti-siphon valve cause this problem? I cannot understand why the secondary jets get fuel but the primary jets do not. Any help would be greatly appreciated. Thanks.
