3L GLP-E Carb setup
JVO90
I'm working on rebuilding the carb on a 2007 Volvo Penta 3L and I can't find any set up specs. I have the GLP-E. I found info on the GLP-D that is probably very similar but does anyone know for sure?
Thanks,
dubs283
Would guess the info is the same for both engines, being of similar vintage and the 3 liter not changing much over the past fifty years.
This is a holley 2bbl? For float height I would measure the existing and set new one to that. Idle speed would be approx 600- 700 in gear on the water. Idle mixture should be final adjust on the water as well
