3L Runs On/Dieseling
NetDoc
Re: 3L Runs On/Dieseling
Dieseling is a sign of overheating of the combustion area. This could mean that the engine is running significantly hotter, leaner or too advanced. Have you checked for a vacuum leak yet? That could really heat up the combustion chamber and cause the hunting you are complaining about. There are a few ways to do this, and you should pay attention to the throttle shafts in the carb as well as any gasketed areas (manifold and carb). 4 spark plugs are relatively inexpensive and easy to change. The colder spark plug just won't self clean as well if there is any oil consumption. I say it's worth a try as it may be the ignition source once the spark has been removed from the combustion chamber. As a temporary work-a-round, you might floor the accelerator AFTER you turn it off. The sudden over abundant supply of air often quenches the hot combustion chamber to stop the dieseling. This is only a stop gap method and you should identify and fix the problem rather than rely on this.
As for setting the engine speed higher: that will make this condition WORSE. The lower the better. The richer at idle the better, especially if you idle for a minute or three before you switch off.
Final note... change your gas. Go for a higher octane which will burn a bit cooler. It won't give you quite the economy as the cheap stuff, but it may rectify your problem.
kidafa
Thanks for the response guys :)
achris; Yes I do have the manuals. Ok ill adjust the throttle cable while pushing the black end in towards the barrel. I think the idle speed at 750/800 will cause dramas.
DonS; What speed should I set it Idling at in the water in forward gear? The cable is currently set to It have to push it a little bit back towards the barrell adjuster so it can get on the throttle lever, so in theory it is pushing the throttle all the way closed, this is correct yes?
NetDoc; I agree with the suggestion to run a higher octane fuel.... Ill try 98RON and see how that goes. The days ive been out have been over 30 degrees C (86deg F) so this would also be working against me.
