3m 4200/5200
Jhoppy
Dose this stuff really need to be used within 24 hours after the tube has been opened like it says or is there a way of making it last longer?
Thanks
Bob_VT
Re: 3m 4200/5200
You mean a caulk gun tube??? I buy the smaller tube and can recap it for later use as long as there is no air/moisture in there.
Air and moisture cure them.
osborn159
Re: 3m 4200/5200
think a peice of duct tape on the open nozzle end would seal it off from air,moisture??????
Robj
Re: 3m 4200/5200
The stuff won't last that long, but I have been able to use it a month after opening it, even longer.
Have a great day
Rob.
Jhoppy
Re: 3m 4200/5200
Thanks, I bought a tube of each and got to reading the (destructions) and did not want to put the hole boat back together in one day. I will try the duct tape or maybe even plastic over the openings I hope it works.
Thank You
Hoppy
Moody Blue
Re: 3m 4200/5200
Need to keep it tightly sealed and cool. Plastic bag or plastic wrap around the nozzle and tape tightly closed. As mentioned, exposure to air and/or moisture (even humid air) will begin to cure it. I've kept mine for over 6 months and still good BUT, urethanes should be used with a year.
