3M 5200 shelf life?
Toddavid
Instructions on tube says that once opened, it must be used within 48 hrs.
What happens beyond 48 hrs? Something so horrible it must not be mentioned?
Seriously, if it has not begun to harden, is it still safe to use, or is some unseen chemical transformation happening that makes it bad to use after 48 hrs?
Re: 3M 5200 shelf life?
Ayuh,.... I keep it in the fridge for awhile, 'n if it'll flow outa the tube, I've used it, without adverse effects,...
though yer results could differ,....;)
ezmobee
Yep. If it ain't hard, use it.
Thalasso
Put a screw in the tube and store in freezer.Thaw before trying to use.:D:D
lakelover
I've had some almost a year old that was fine to use, but I had to cut the tube open on the bottom cuz the top was cured.
saumon
Just a hint: 5200 cure when exposed to water (humidity in the air). People report that in the desert, it take forever to cure. So, any low-humidity environment (in a zip-lock, in the freezer) will add shelf-life.
smokeonthewater
I've used it after a couple years when stored in the freezer and it has been just the same as new (once warmed up) then I put it back in the freezer... have some in there that may be 4 years old or so and I'm sure it's still fine
tanuki
Ditto.... in zip-lock bag into freezer.
