3m 5200
PUP300
I will be sealing a few transducer holes with 5200, nut, bolt and washers through aluminum hull. My question is, once I tighten the coated bolts, nuts and washers, can I take a razor blade to clean up the excess 5200 around the washers or will that ruin the seal? I am hoping I can clean it up a little and the seal behind the washer wil still be in tact.
Thanks for any responses.
fishrdan
Re: 3m 5200
Clean up the excess 5200 with some paint thinner and paper towels before it cures. I wouldn't worry about ruining the seal, you are just wiping off the excess that squeezed out.
Bob_VT
Re: 3m 5200
Remember to use stainless bots ;)
Friscoboater
Re: 3m 5200
I use paint thinner to wipe an excess off. Be careful. The stuff gets everywhere and does not like to come off your hands.
PUP300
Re: 3m 5200
Thanks for the replies, appreciate it.
thompy
Re: 3m 5200
when i worked for yarcraft, i would wipe excess away right away with a rag then acetone
