Woodonglass
- Joined
- Dec 29, 2009
- 25,929
Re: 3M Fiberglass??
These might help you understand how to do it... These were created using the assumptions you are using Poly resin and you will precoat all of the wood first. You do NOT have to use a Layer of 1708 as a final layer for the deck. You can just use 2 - 3 layers of 1.5oz CSM if you prefer. Tabbing up the sides of the hull proggessively 2,4 and 6 inches. Hope these VISUALS help. Make sure to grind the hull down to fresh glass so the new resin and glass will bond properly.
(Click the pics to enlarge)
