3M Restorer Question
pokman
I just got a bottle of the 3M restorer/wax and I was wondering if anyone has done this completely by hand? I don't have a buffer, I have light to maybe medium oxidation towards back of the boat. I know most use the buffer but wondering if anyone had luck doing it all by hand.
Pez Vela
Re: 3M Restorer Question
Luck has nothing to do with it ... this guy tried it one too many times.
You really really don't want to do this by hand.
Also, I wouldn't be surprised if you have to wet sand first (something like 800, 1000, 1200, 1500) to end up with a good job.
Bob_VT
Polisher's are really not a bad investment and harbor freight or northern tool have decent prices. Not an orbital but a real polisher will help.
mtrainTurbo
It depends on how old the boat is, and how bad the oxidation is.
If you have a relatively new boat (lets say 5 years old or so) you can do this by hand, using Fiberglass Restorer. Light oxidation means you can run your hand on it and not much or any chalk on your palm.
When it comes to polish, its like sanding - do the bare minimum necessary to do the job. Wet sanding is The Nuclear Option, and generally only reserved for boats that are old and have oxidized to a dull light gray in color.
5 - 15 year old boats that have gotten any care at all (an occasional wash, or some application of a towel at some point) generally can be polished with a high speed machine buffer. Products I use with this approach are:
3M Super Duty compound
followed with
3M Rubbing Compound
followed with
3M Finess-It glaze
followed with
Collinite Fleetwax (in paste form)
I do this twice a year - once in the spring, and once in the fall. The first time I did it took all day due to the age of the boat (1986, and not kept up to "My Standards"), and i was very sore for days afterward.
However, a funny thing happened: Once you remove 10 years of neglect, the following fall, all I needed to do was run over it with some light compound (by hand), the Finess-It, and the wax, cutting most of my time invested. I was able to do the boat in 3 hours.
Proof? Okay. Here's the day I dragged it home...note the fading near the rear rails, thats not a shadow...thats where the original cover ended:
And when I was done with it:
pokman
Thanks for the reply guys, I figured by hand would be a pain. My buddy has a 9in buffer so this weekend I am going to get her done. Any advice for applying or buffing it off?
dingdongs
if u have a white boat and its looking a bit yellow buy yourself some neat oxalic acid crystals.mix a couple of tablespoons with a pint of water and get yourself a good thick looking brush and just paint it on.you will see the yellow come off before your eyes .do an area what u can do in 5 minutes and rinse off immediately.keep a bucket and sponge handy.can be done on the trailer and in an hour or two for a 20 footer.will remove rust stains too.boating products use this as the main ingredient, colour it and charge an arm and leg but 1 pint just done my whole boat.polish was simple as no cutting compound needed to get rid of the staining.
airdvr1227
Using a buffer is a finesse job. Don't stay in one place very long...keep moving. You'll be Armstrong by the time you're finished.
