3or4 blade..... Stainless or aluminum.....
grooter
1990 Donzi 22 ft open boy 5.0 ltre Omc cobra outdrive..... Flat out 38 maybe 40 by myself...... Would love a little more out of it
dingbat
A 4 blade will improve your hole shoot but reduce your top end.
Sea Rider
Is that per GPS or is an assumed number ? What about max wot revs achieved at that speed ? Can't play with props if you don't know max rpm and if inside min-max safe rpm range for that engine.
Happy Boating
steelespike
We need your prop size, near the base of the blades or under the prop nut, hp and or gear ratio.do a lightly loaded wot run get us the accurate rpm and gps speed.
