4 1/2 " grinder
oldhull
whew... i'm starting to learn how shallow my knowledge is<br />ok... i got this 4 1/2 " grinder an most posts tell me to get a diamond cutter blade, great<br />can ya'll be a little more specific mebe the make and or style? and where do i get them my local sears dont even know what i'm talking about? are these blades for masonary? and what for grinding? sorry guys(gals)
Paul Moir
Re: 4 1/2 " grinder
They're used a lot for cutting ceramic tile. So you'll be able to find them at any home centre. But the best prices on them are usually at discount tool stores. Up here I get mine at Princess Auto, I guess something like Harbour Freight would be where you would get it? Before you go shopping, make sure you know the arbor size of your grinder (5/8 or 7/8 usually).<br /><br />There are two kinds of these discs (they all look like a smooth metal wheel), one with little slots cut in it, and others that are solid. You want the one with slots which is used for dry cutting. They're really quite amazing - try hitting a brick or a bit of stone with them.<br /><br />I've only used common metal grinding wheels for grinding - the ones that are about 1/4" thick and say they're for ferrous metals. But I think a heavy grit flap disc might work really well too - maybe much better than a solid wheel. These are like a grinding wheel with a hundred little sheets of sandpaper glued to them.
surlyjoe
Re: 4 1/2 " grinder
flapper disks are amazing, as well as a good foam wheel with the hook and loop paper disks makes fairing alot easier. just try not to get into the original layup too much
sailsmanship
Re: 4 1/2 " grinder
Diamond wheels.. you can get them at Power Tool Sales on Angola Road or Cobra Equipment off the AW Trail. Best bet for grinding is either Performance Tool & Abrasives on Monroe Street or T & S Tool on Airport Highway. What you use for grinding depends on what you are grinding.Let me know
oldhull
Re: 4 1/2 " grinder
sandpapermann1..<br />just read your reply...sorry<br />how do we get together?<br />pun2b4u@hotmail.com
oldhull
Re: 4 1/2 " grinder
fiberglass <br />and some rotted wood
surlyjoe
Re: 4 1/2 " grinder
diamond wheels work on everyting. they are a miracle of modern science! :thumbsup:
KRS
Banned
Re: 4 1/2 " grinder
I think cutting out the rotting wood and a little of the good wood past the rotting stuff would be the advisable thing to do.
oldhull
Re: 4 1/2 " grinder
well... i thot i was replacing the transom but because of all the owners repairs it looks like i am going down to old hull removing everything but original hull there is a weird stringer looking kinda thing down the middle of the boat it might be somekinda bildge trough 1"x6" planks laid on foam 6" side running abeam then covered with looks like fg matting and forming a trough 5" deep wish i could show you all pix it's weird
tashasdaddy
Re: 4 1/2 " grinder
it's probably a control chase built into the hull by the mfgr. who used the same hull type for different topside finish. center console/ side console.
oldhull
Re: 4 1/2 " grinder
so tashasdaddy do you believe there might be stringers below that? this is a tri-hull and just either side of that (chase) is hull<br />i've seen pix of diff topside finishes for this hull type thnx
sailsmanship
Re: 4 1/2 " grinder
Sorry been away for awhile. From what I have seen on further posts,if you want to cut, use a diamond blade,but if you want to grind, use a resin fibre disc. Grain of choice would be silicon carbide 24 grit, but in a resin fibre disc it is hard to find anymore. Aluminum oxide would be easier to find and would do o.k. If you want to know anything more specific either post it here or you can e-mail me at myklskc@msn.com
