Re: 4.3 Carter/Weber 9600 Carb Rebuild question - check ball
I'm talking about under the main discharge nozzle (squirter nozzle on primaries).
It's a check valve so air isn't sucked into the float chamber and fuel can't be sucked up through the nozzles and into the air stream....
Have a look at page 18, section 5C, of the service manual. They are parts numbered 27 & 28... and described on the next page as
27 - Check-weight (or Check-spring, if so equipped)
28 - Check-ball
Chris..........
